Tools And The Shop => General Tool and Machine Discussion => Topic started by: Muddy on Aug 30, 2025, 07:23 PM
Title: Tool Abuse
Post by: Muddy on Aug 30, 2025, 07:23 PM
We all know them
don't use that screwdriver as a prybar....
Not for impact use....
Etc.
I'm sure we're all guilty in one way or another.
So what is it that your guilty of?
Me? I use anything with in reach as a hammer. Ratchets, pliers, wrenches if it's within reach an I need to hit something it's a hammer now. (Including my hand/fist).
Title: Re: Tool Abuse
Post by: 1965 Comet Caliente on Aug 31, 2025, 07:38 AM
Can't think of anything specifically, but I finally learned that taking a couple of minutes to get the right tool for the job can save you a lot of time and aggravation.  8)
Post by: Rural53 on Aug 31, 2025, 10:06 PM
Dad and I did grind down a couple of spanners to adjust the tappets on the little Continental N62 I was trying to get running on the Allis-Chalmers Model G I was restoring.
Post by: AbiggerGarage on Sep 01, 2025, 04:40 AM
One that I am guilty of, is when my late boss, best friend passed away, I was asked to move into his home (take care of the pet and help with the estate, during Covid).  Went to go do things like find out what paint was still good, what had good names or paint codes, etc.
I used the bent Craftsman screwdriver that he had used to open the paint cans and stir stuff, as it was left with the paint by the last painter he had hired.  Not sure if it was abuse at that point.
I have often wondered about chrome sockets on impact drivers, not impact wrenches.  They barely do inch pounds and it wasn't until later I saw 1/4" impact sockets (and by that time, I started buying the loose magnetic ones I could find).
Not having an impact rated or rear tipped screwdriver, yet pounding on the head to get a screw to start turning due to rust.  This was on an old piece of furniture where the sloted screw was rusted to the square nut, that I could just barely get a adjustable head on.
Post by: bmwrd0 on Sep 01, 2025, 10:34 AM
I have used a chrome socket with an impact gun. Sometimes you just need to do it.
Post by: Highland512 on Sep 02, 2025, 11:17 AM
Leverage amplification devices on ratchets.
Post by: Hickory n Steel on Sep 02, 2025, 02:01 PM
The only thing for me is occasionally using a socket or extension as a drifting punch, but when I do this I'm only hitting with brass or plastic and never hammering  very hard.
For me make it a point to have enough hammers around that only my hammers are hammers,  and enough pry bars around that only my pry bars are pry bars.
I have more tools than I need so I rarely have to misuse tools.
Post by: Uncle Buck on Sep 03, 2025, 07:26 PM
Quote from: bmwrd0 on Sep 01, 2025, 10:34 AMI have used a chrome socket with an impact gun. Sometimes you just need to do it.
Guilty of the same years ago when I didn't have as .any tools. Not so much in the last twenty years.
Post by: Uncle Buck on Sep 03, 2025, 07:29 PM
I have been guilty of hooking the ends of wrenches together to gain leverage. I was never a big fan of cheatering ratchets and in fact don't recall ever doing that.
Post by: j.a.f.e. on Sep 03, 2025, 10:49 PM
Quote from: Uncle Buck on Sep 03, 2025, 07:29 PMI have been guilty of hooking the ends of wrenches together to gain leverage. I was never a big fan of cheatering ratchets and in fact don't recall ever doing that.
I, too, hook wrenches together. I can't think of a time I've cheated a ratchet. I either use a longer one or larger drive or breaker.
Post by: AbiggerGarage on Sep 04, 2025, 05:23 AM
I can think of twice I hooked ratchets together.  Although I believe one of the old timers I knew, would have told me it wasn't cheating in there day, as they hooked a boxed end wrench on the end of a DOE wrench, to get into one spot and change the angle of access.
My two times one was for leverage, the other, I used a pipe over a Snap on flank drive, as those wrenches were much thinner to the point of being uncomfortable to use and putting a pipe over it, gave me something that worked with my hand (didn't really extend it).  That was what me put off on a Snap on wrench set.
Post by: Muddy on Sep 04, 2025, 06:24 PM
Quote from: Hickory n Steel on Sep 02, 2025, 02:01 PMThe only thing for me is occasionally using a socket or extension as a drifting punch, but when I do this I'm only hitting with brass or plastic and never hammering  very hard.
I use my harbor freight impact sockets as bearing/bushing drivers all the time. I have an old cornwell 3/8 extension that got bent when trying to press a jeep hub bearing out. It has become extremely useful for knocking the steer link pins out of hyster forklifts due to its shape.
Post by: Hickory n Steel on Sep 04, 2025, 09:04 PM
Quote from: Muddy on Sep 04, 2025, 06:24 PM
Sockets definitely work well for this kind of thing.
I will say that I have thoroughly abused some random old crappy imports in this way, but I got rid of all the crap tools years ago and was only really thinking in regards to tools I still own and care about.
Post by: Heiny57 on Sep 05, 2025, 10:32 AM
Quote from: Highland512 on Sep 02, 2025, 11:17 AMLeverage amplification devices on ratchets.
I love that term, that almost makes it's use justified. Hahaha
Post by: goodfellow on Sep 06, 2025, 06:45 PM
Guilty on all counts. Whatever it takes to get the job done. I've used chrome sockets for years with my 3/8" impacts and beat on screwdrivers mercilessly. I regularly use 1/2" and 3/4" drive sockets as pressing dies in the 20T shop press.
I did break down recently and picked up a set of steel bolstered screw drivers from HF. Reasonably priced and they work well. Love 'em and I don't mind modifying them as needed.
https://www.harborfreight.com/8-piece-bolstered-screwdriver-set-94899.html
Highly  recommend these things
Post by: Uncle Buck on Sep 07, 2025, 09:28 PM
Quote from: j.a.f.e. on Sep 03, 2025, 10:49 PM
Exactly my thoughts. For the really heavy stuff I have a Bertha ratchet (decommissioned 3/4" drive 3' long torque wrench) I retrieved from a local scrap yard for scrap price still fully functional. Only had to break it out once for an axle nut on a front wheel drive car. I was shocked when it wasn't enough without some torch heat!
Post by: Uncle Buck on Sep 07, 2025, 09:45 PM
Quote from: goodfellow on Sep 06, 2025, 06:45 PMGuilty on all counts. Whatever it takes to get the job done. I've used chrome sockets for years with my 3/8" impacts and beat on screwdrivers mercilessly. I regularly use 1/2" and 3/4" drive sockets as pressing dies in the 20T shop press.
High recommend these things
In over 30 years of owning my mix of 3/4" & 1" sockets, rarely have i ever used the sockets on the drive tools. Amost exclusively I have used them in pressing operations, so you bet I get that!
Years ago before I had a decent range of impact sockets i too used some chrome sockets when I had no choice to impact with. Fortunately I never did any serious damage to one doing so.
Post by: Highland512 on Sep 08, 2025, 08:27 AM
Quote from: Heiny57 on Sep 05, 2025, 10:32 AM
You got to know how to fill out them incident reports to make it sound less bad  8)
Post by: 1965 Comet Caliente on Sep 28, 2025, 04:30 PM
Was at Horror Frights today and figured I'd check them out but no dice, the China Buffet was out of them.
