Vehicles => Tractors/Mowers/Heavy Equipment => Topic started by: OldCarGuy on Feb 28, 2026, 05:07 PM
Title: My 1992 Ingersoll 3118 Garden Tractor
Post by: OldCarGuy on Feb 28, 2026, 05:07 PM
This was my uncle's tractor that was left to me by my Aunt. His pride and joy. He cut several acres of grass and plowed a garden that covered another acre. In the winter he'd use the 48" snow blower for the his and nearby neighborhood driveways. It had 15 years of heavy use and didn't run when I picked it up. Needing some work along with a paint job to get it back on line.
The 1992 invoice price was $9,200.00, that's $20,600.00 today. This wasn't your average tractor and weighs 700 pounds. Compared to today's John Deere 48" weighting 250 pounds less with a price tag of $2,800.00. What do you get for the extra bucks other than 250 extra pounds? First off the Ingersoll is a garden tractor and not simply a lawn tractor. It has an 18HP Onan twin cylinder air cooled engine that drives a hydraulic pump. Everything is powered by hydraulic oil. The 48" 3-blade deck, lowering deck movement, the 3-point hitch,  power steering, along with attachments 48" snow blower, chipper, log splitter, tiller, and hydravac.
The Ingersoll is an amazing tractor. None of my riding mover come close. Having power steering, it's a cinch to cut the lawn. It cuts at idle speed, sips gasoline, and nearly as quiet as an electric model. More like driving a Cadillac compared to a tank...
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/a94929b8-f791-4e6a-a098-b246c387ed76.jpeg)
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/ec619f3f-b00b-47c2-a008-330b3539feb2.jpeg)
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/92899b0c-fab0-4dfa-adf5-315de543c151.jpeg)
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/9f4ad830-918e-44cf-954c-7bcb1b720c26.jpeg)
48" snow blower spiffed up
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/a431c478-0110-403c-b149-f78b45a773fd.jpg)
Single bottom plow, most likely I'll never use..
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/e5cf93f1-d041-4e45-8ae7-36c078bb60a2.jpg)
Last fall the 35 year old tractor had a major mechanical failure. The engine started to bog down and eventually quit. Now barely turns over. Put it on my lift to get it running for this season... Having it waist high makes it easier on my back and easy to get under.
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/b015935c-cc92-4300-8e1a-930d3889f464.jpeg)
I disconnected the hydraulic pump from the engine. Diagnosing if it's the pump or the engine. Extremely close quarters.Took several hours just to remove four bolts.
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/20eb7aff-dd7d-4809-82d4-05b8ffc944aa.jpeg)
Picture at another angle..
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/e22d5586-e3f5-4c2e-8353-91358c08ebcb.jpeg)
Still turns over slow.. Most likely the pump is okay. So the problem must be in the engine. Hope it's not all busted up inside!
Took another two hours to remove air filter and sheet metal shrouds.Then five minutes to remove the two heads...
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/c2af3e61-771c-4916-8ffa-f0ad36e0b3e1.jpeg)
Spread out parts on a workbench..
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/df8ad61d-7fbb-4ca3-a6e2-b20910c35a07.jpeg)
The cylinder walls look great.
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/a502fef6-d33f-4fd3-af73-ee33b8b7a2ee.jpeg)
With out compression the engine turns over a tad better using the starter motor. But I could hardly turn it over by hand. The piston go up and down. And valve action is good. I'll have to tear it down more to find the issue..
Title: Re: My 1992 Ingersoll 3118 Garden Tractor
Post by: OldCarGuy on Mar 08, 2026, 09:43 AM
Having the 3118 on my lift made it easier to reach both the top and bottom side. Started by removing the oil exchange cooler. Then removing wires. Cables, starter, etc. I needed the remove the mowing deck to reach some bolts on the underside. A nylon strap and my bridge crane facilitated removing the engine. The set it on my elevated table, drained the oil, and started the tear down.
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/44cf8f28-fe81-48d7-a301-da75d870938b.jpeg)
Setting the engine on my lift table. Letting the oil drain..
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/bf8fe186-8e0c-468b-92e1-17aa2d9663e2.jpeg)
Removing the oil pan and see what's inside.. Looking GOOD so far..
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/12f71f0b-6853-42c9-83ed-832b17650152.jpeg)
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/fe68e5fe-12aa-4fbb-91e8-d99855d21a7f.jpeg)
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/c1180e89-ccaf-42cd-9c20-aefe77d39b41.jpeg)
Using good quality oil and frequent oil changes pays off! Even the oil is clean....
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/5251d2f8-4cfe-4bd8-8660-62707b464a9d.jpeg)
After half a day, it was time for dinner and relax. Another day I'll dive into removing the fan shroud and disassembly.
Post by: Uncle Buck on Mar 11, 2026, 03:58 PM
Wow, super clean!
Post by: Muddy on Mar 12, 2026, 05:04 PM
Those were good tractors. Looks like your uncle maintained it well.
Post by: OldCarGuy on Mar 13, 2026, 07:34 AM
Quote from: Uncle Buck on Mar 11, 2026, 03:58 PMWow, super clean!
Quote from: Muddy on Mar 12, 2026, 05:04 PMThose were good tractors. Looks like your uncle maintained it well.
I'm amazed that this 35 year old tractor engine is so clean too. The type of oil and frequency of oil changes was the secret. Most of the engines that I rebuilt are 75 years old or older before detergent oil was introduced. It was common to see sludge buildup throughout the engine. So thick a putty knife was needed to move it.
Post by: OldCarGuy on Mar 13, 2026, 08:00 AM
Once I removed the PTO end bearing cap. The crank turned freely along with the pistons and valve movements. The lower side of crank shaft journal is to size 1.999 to 2.000 diameter. The outer end picked up some babbitt off the bearing. That I should be able to polish off.
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/60989138-0070-418f-aa10-fd790f1e2375.jpeg)
I'd say the bearing is toast and needs replaced. If bearings weren't readily available, as some of my antique cars. I would re-babbit the shell then machine... However the cost of a replacement doesn't justify...
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/4616ad37-f63a-43fb-9d32-8a4d648418e4.jpeg)
While I was ad it I removed the connecting rod end caps.. That looked new as the crank journals.
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/3f09db66-9ad6-4e0f-b15d-d3ae32ba332d.jpeg)
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/89a320f9-25f7-4243-bc30-37e3fc0e4172.jpeg)
I have to wonder why the bearing was damaged. My inclination then was to look for the root of the problem... Removed the flywheel and cam gear cover. Once again it was clean as a whistle!
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/1ad8db7e-3ecf-4b3e-be95-427d0ca4ce98.jpeg)
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/f15f4ed3-2ab9-4a06-9ec4-3f341da42aa8.jpeg)
I noticed a small section of the gasket protruding between the halves of the pump flanges. Now why would that happen after 30 years? Removed and examined the oil pump components. No noticeable wear. The small gear key was intact. Could the missing section of the gasket cause loss of oil flow?  Since the damaged bearing was the farthermost from the pump...
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/acca5c8b-77d0-408f-bd08-c11321cdb266.jpeg)
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/3d2bf909-d24e-45a9-bf15-505c183f238e.jpeg)
In any event it was good thing that I didn't continue operating the tractor. Rather delving into the issue. I have the main bearing and all the gaskets on order. With any luck the old gal will be up and running i a week...
Post by: OldCarGuy on Mar 22, 2026, 04:54 PM
No much progress on the tractor since my last posting. Other than removing grease, grime, and dried mud from years of normal use..
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/dc5a0bb5-c54d-49df-91c6-82645168adba.jpeg)
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/21520036-1182-4c53-a51c-4269ab11b17b.jpeg)
The Ingersoll tractor got sidelined to replace the windshield washer reservoir tank on my Smart Car. Some call it a SwatchMobile. Conceived by Swatch, while engineered by Mercedes. "Smart-Mercedes+Art" = Smart Car...
Since it's only 8 feet long. The task at hand designing is like putting ten pounds of potatoes in a five pound bag. Needless to say the whole front end of the car had to be removed to replace a simple reservoir.  Turning a 15 minute job into nightmare.
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/1988d3a3-84ef-4409-8017-f948db78ccb3.jpeg)
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/c2b2a2e3-d378-4650-bc28-cf12832a81c0.jpeg)
After putting the car back together...
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/d7286b2a-b642-4e10-a5e1-0c42119a0656.jpeg)
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/972c8beb-f371-4035-b7b1-9bdc47599163.jpeg)
Post by: OldCarGuy on Mar 24, 2026, 08:50 AM
After replacing the Washer Reservoir in the Smart Car. It's back to the old Ingersoll Tractor. I installed the new main bearingh into place using my Dake Hydraulic press..
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/cdf31cba-e4f9-42b7-ac21-6731123c6885.jpeg)
In another five hours I assembled the engine. Then dropped it into the chassis.
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/8d94f300-0ccc-419e-9cb9-6c2f63fc7338.jpeg)
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/2edab454-6995-4d25-b9d7-f59c054ce8c3.jpeg)
Hopefully I'll finish putting her together over the next two days. And have the Old Gal up and running in time to cut the grass...  8)
Post by: OldCarGuy on Mar 27, 2026, 09:02 AM
I finished putting the old gal together today. I have to report she started right up and engine runs perfectly. But noticed a bad oil leak coming from the underside. The leak was coming from a JIC right-angle fitting. Snugging the female swivel side of the fitting didn't stop the leak. After removing the fitting I found female swivel cracked.
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/27d37671-40b0-4f9f-adf2-5e61e124decc.jpeg)
Picked up a replacement fitting. And installed a it... Leak solved.
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/78e9f82a-9503-4762-a2b2-863b50b11eba.jpeg)
While the tractor was on the lift. I installed three new blades..
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/85d0ecff-1036-42e9-ad0d-574d31ed7647.jpeg)
Took the tractor off the lift and spent the next hour mowing the yard. That made me realized why I love the Ingersoll Tractor so much!
Post by: goodfellow on Mar 30, 2026, 07:56 AM
Money well spent on a quality piece of machinery that can be passed down to another generation.
Post by: Uncle Buck on Apr 08, 2026, 05:45 PM
Quote from: OldCarGuy on Mar 22, 2026, 04:54 PMNo much progress on the tractor since my last posting. Other than removing grease, grime, and dried mud from years of normal use..
HOLY MOLY! It takes a brave man to drive that! I am NOT a brave man I guess!
Post by: OldCarGuy on May 17, 2026, 01:07 PM
Over the past six week and several hundred hours, my Ingersoll performed like an absolute dream. This week all things hydraulic shut down, No power to the wheels, deck shut down, and no power steering.. But the engine kept running. Sadly I was caught mowing at the far end of my property. And towed it back to my garage with my baby Deere Tractor. Once on the lift I could see that the pump shaft was not  turning while cranking the engine..
Rather than removing the entire engine again. I removed the four screws that attaches the pump shaft flange to the engine. Then removed all the pumps hydraulic lines, making enough room to remove the flange from the pump shaft... There are two set screws on the flange, 90 degrees apart, with  one directly over the key. There was no Woodruff Key!  I'm certain the tractor ran 35 years with only the two set screws. As the woodruff keyway was packed with dirt and grim. Fortunately I have hundreds of shaft keys, including Woodruff style.. Reassembled and is now runny again...
I never removed the adapter off the pump shaft
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/cc13abb5-788b-4028-843e-05aefba1c478.jpeg)
Tight quarters to remove hydraulic lines to move pump from the adapter
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/9a88b863-ae03-4c8e-a084-6a5b8362d54b.jpeg)
Wooddruff key
(https://hosting.photobucket.com/0b94a146-b045-4f03-9b2b-0d502ecdc6eb/624742e0-d75c-4b45-aafd-a40542ffd3e9.jpg)
Post by: Uncle Buck on Oct 23, 2026, 07:57 PM
So you fixed it and logged a summer of enjoyable use? Not planning to put it to use plowing or blowing snow with it this winter are you?
Incredible machine.
