I've been spending some time reorganizing my garage workbench recently, and I realized that a few small changes can make a big difference when working on cars or other DIY projects.
The first thing that helped was separating tools by how often I use them. Screwdrivers, sockets, pliers, and measuring tools stay within easy reach, while specialty tools are stored in labeled drawers. I also started using small trays for bolts, clips, washers, and other hardware so they don't disappear during a project.
Another useful idea is making custom holders or trays for the workbench. I've seen some interesting DIY organizers made from wood, metal, and epoxy resin (https://bondcraftor.com/collections/epoxy-resin), especially for small parts, drill bits, or frequently used tools. It's a nice way to customize the workspace if you enjoy making your own shop accessories.
Lighting also made a bigger difference than I expected. Adding a bright task light directly above the workbench makes it much easier to see small parts and inspect surfaces properly.
A few things that have worked well for me:
Keep frequently used tools within arm's reach
Use magnetic trays for nuts, bolts, and screws
Label drawers and storage bins
Keep cleaning supplies in a separate area
Add good lighting above the main work surface
Leave some empty bench space instead of filling every inch with tools
I'm still improving my setup, so I'd be interested to see what everyone else does.
What is one garage organization upgrade that made the biggest difference for you?
definitely having storage and organizing within arms reach of my workbench.
bright lighting was a general major improvement across the board for sure .
Lemme think on this a bit.
