8.8 swap into the 85
Started by Elroy, Jan 30, 2025, 05:40 PM
Elroy
The 7.5" diameter ring gear was marginal in strength, The original 2.73 ratio was way too high and needed to go away. What a fine rusted piece of crap.You cannot view this attachment.You cannot view this attachment.
Elroy
#1
This 3.73 ratio 8.8 axle with Yukon 31 spline, 5 stud axles should do the trick just fine.You cannot view this attachment.
Elroy
#2
A little prep is in order.You cannot view this attachment.
Elroy
#3
And like magic, it now lays rubber with ease.You cannot view this attachment.You cannot view this attachment.You cannot view this attachment.
Elroy
Big brake rotors are nextYou cannot view this attachment.
Excellent Elroy -- and thanks for sharing that install. Love it!
what?
no rubber laying action pics?
Elroy
Quote from: skfarmer on Feb 01, 2025, 10:14 AMwhat?
Nope.
It actually hooks up well with the drag radials.You cannot view this attachment.
Nice Work!
That is some CLEAN sheet metal up under there.
Keep an eye on those attachment points as over the yrs I've seen where the good hooking ones have a chance to rip the metal at the stress point.
Gonna want to see some slips or is this just for fun? Drag n drive?
Quote from: TexasT on Feb 02, 2025, 12:10 PMNice Work!
For sure! Are you certain that car didn't come from Arizona?   ;D
