Alternative Refrigerant for R-12 System --
Started by goodfellow, Jan 18, 2025, 09:50 AM
First -- don't try this with your new car or daily driver. This experiment is being done on my junk truck and I will attempt to document the results over the next few weeks as to the effectiveness of this alternative method. Let me take the risks before you ruin your own vehicle. PLEAAAASE!!!!
This is my old '88 Mazda B2600 4x4 with the 2.6L Mitsubishi carbureted engine. I converted it to a Weber several years ago and really want to get this back on the road as an everyday driver. To do that I had to fix the AC system. The original R12 charge had leaked out years ago due to a faulty Schrader valve, and since R12 is so hard to come by these days, and R134a is not compatible with the old mineral oil based R12 systems, I decided to try the following --- Electronic Keyboard Duster!!
That's right -- the electronic keboard duster kits are nothing more than a refrigerant -- namely difluoroethane; which is R152A -- it's cheap enough at Wallmart $11 for three 10oz cans. That's quite a savings over the cost of R12. BUT what's even better is that the R152A has most all of the heat transfer and compression characteristics of old R12.
First thing to do is purchase a side-tap can dispenser because the Duster cans don't have a standard R12 or R134a Schrader fitting. Also, you must tap these cans at the strongest point -- about 1/2" up from the bottom, or you'll crush the can and get a massive leak. Be gentle when tapping and don't force it.
You will also need an R12 gauge set -- or a modern set that read multiple refrigerant types. I attached my set as usual -- low side on the compressor -- high side by the receiver/dryer. Then I replaced the faulty Schrader valve on the low side and pulled a vacuum for an hour.
After the vacuum, the system held 30 inHG vacuum for 1 hour and I was pretty confident that it was air tight.
I then tapped my can and proceeded to fill the system with the 152a air duster refrigerant. First without the engine running, and then after the system equalized a bit, I turned the AC on high and recirculation on internal (no external air flow).  I put a thermometer in the vent and proceeded to turn on the AC switch. The compressor instantly kicked in and the pressure dropped to 22psi on the low side. I opened up the gauge and added the 152A slowly to increase pressure 10psi at a clip and then shut the gauge valve off to let high side pressure stabilize and to check internal temps.
I did this procedure about three/four times until the low side had stabilized on 42-45 psi and the high side at 200-235 psi. I used about 1.5 cans -- or about 1lb of refrigerant to get the inside temp down to about 54F. Then I revved the engine for a few minutes and the gauge dropped just below 50F. I thought that was enough and unhooked all my gauges and took the car for a spin around the block. Within minutes the temp was in the 44-46F range -- PERFECT!!
At this point I would have to say that we have a success, BUT only time will tell. I'm not recommending anyone to do this to their car. This is an experiment to see what works and what pressures are viable for this type of refrigerant. One thing is for sure, it definitely does not behave exactly the same (pressure and volume wise) as standard R12. My system required less R152a than R12 -- I filled the original Mazda system back in the day with 20-22oz of R12 (a bit less than 1.5lbs.). This 152A takes less -- about four-six ounces less.
Let's wait and see what the long term implications are in this experiment -- I'll keep you posted.
BTW -- I'll debunk the myth right off the bat. This stuff is NOT flammable to any high degree. I tried spraying it across an open propane torch flame and it did not ignite -- in fact it extinguished my propane flame every time I tried to do this experiment. That doesn't mean it will never flame -- but it doesn't seem to be explosive.
If this works in the long term, the I will use this in my Jaguar E-Type due to the fact that it has a vintage OEM piston style Tecumseh AC compressor system.
Onward
Addendum -- Here is a Korean Advanced Institute of Science and Technology report about the efficacy of using R152a as an automotive refrigerant. Very interesting conclusions.
http://www.sae.org/events/aars/presentations/2008/manhoekim.pdf
This Mazda AC system has been running great on a cheap R12 subsitute (cheap keyboard duster gas) for over five years. It hasn't been driven much this summer, but when i finally did take it for a drive I noticed that the AC wasn't as cold as before. This thing gets to freezing and when working properly, it has the coldest AC in our family fleet -- next to my Caddy DTS. So when it's just blowing cool air there is something wrong.
I checked the belts and hooked up the gauges and found I was low on gas -- so there is a leak somewhere. A quick stop at the local NAPA found this little R134a dye injector kit and along with an R12-R134a conversion adapter I was able to inject some dye into the low side port of this R12 system
Hook up the gauges and the air duster can, turn on the compressor, and add refrigerant through the adapter -- it will suck the dye and the refrigerant into the system. Cool little setup.
It's blowing cold again, and after a few days I'll use a black light to see if there are any visible dye traces in the lines, or other parts of the system.
It's been sitting outside for a long time, but was used a lot in the winter, so I gave it a quick bath and a new coat of wax. Still looking good three years after I did the driveway paint job. That Valspar tractor paint holds up -- but the Ford Red did fade a bit to a more lighter orange. That's no big deal for this vehicle since it matches the old GM colors scheme much better.
