Vinatge early 1960's Marquette Battery Charger - Refurbish
Started by goodfellow, Jan 18, 2025, 09:19 AM
Decided to give the old Marquette a look today. I'm constantly amazed at the simplicity of the design and quality of the components that went into these old machines. There is no comparison with today's machines!! Modern technology may be able to provide more functions at a lower cost, BUT just looking at these 50 year old components says a lot about how American manufacturers felt about lasting quality. These thing were expensive, so they built them to last!! -- Amazing ---
It's a bit beat up, but very salvageable!!
Look at that massive transformer!!!!!
Hooked it up to a battery and it started chargin'
Time to strip this charger and take inventory!
Cables and silicon rectifiers are MASSIVE -- this is truely "old school"
Working slowly form the top, I strip the components with the wiring harness attached -- makes it easier to clean and inventory the parts
The fan motor was the first item to get removed, cleaned, and lubed.
The oil hole was filled with some 30W non detergent and the motor spun like new. The motor and fan were cleaned and are ready to be reinstalled.
The transformer was next -- This thing is heavy.
Some new wires will be required -- there is rodent damage, but that's not a "show stopper"
Everything is removed from the carriage --
The carriage is cleaned, sanded and prepped for paint
Cables and clamps will get cleaned and refitted with new connectors. the wheels will get media blasted and painted gold.
First task is to strip the ammeter and clean/paint the rusted housing -- Before and After
The bezel plates were trashed and corroded. They're aluminum, so they are pitted and oxidized. The plates came out OK with a good dose of lacquer thinner --
They cleaned up well enough to make the project respectable again.
Last thing for today -- the carriage was prepped and received it's first two coats of paint. That will get sanded with 220 grit tomorrow and one more coat of paint will be layed on wet.
That's it for today -- time for an adult beverage :occasion14:
Good night guys!!
OK, let's finish this thing up!! I'm sick of looking at it!! :toothy9: -- Not really, but I did bust hump to get it done today. It was a challenge since it's damp and rainy outside; which makes paint almost impossible to cure -- but I managed.
First thing today was the front cover. After sanding I masked the decals off with tape and proceeded to cut the lettering and outlines with a razor blade
I then turned it over and shot the red basecoat. I also shot he final red coat on the carriage (after it was sanded with 220 grit)
While I was in a masking mood, I decided to sand and mask the control cover -- the masking was for the instruction decal on the inside
This is the gold color I finally settled on -- not perfect, but when it dries it's pretty darn close
The front cover "red" basecoat had dried enough by now so I shot the the gold half-tone on the front -- looks really good, this paint covers and dries fast.
While all the paint was drying, I switched back to reassembly -- I cleaned the switches and wires with WD-40 and replaced two wires that had been chewed on by some critter.
I put down clean towels and started to get all the guts back in the carriage
Good pics and some simple schematics and notes help make this job go quite quicky
Cords and cables were cleaned with my "patented" lacquer thinner wipe down, and then cleaned again with WD-40. This makes them shine like new!!
The clamps were also given a good wire wheel treatment and the look like new. Tough stuff these old clamps.
The bezel and switches were reinstalled in reverse order of removal (I write down the sequence of removal on a note pad)
The 110v electrical connection for the fan and the accessories were made next
The charging cables were reconnected to the rectifiers in proper order -- and the charger was pretty much done with the electrical hookups
Next came the wheels. I found that a quick way to paint wheels is to cover them entirely with packaging tape (it's easier to trim and cut with a razor) and then just cut out the center hub for spraying.
This sure beats trying to mask the rim first. It only takes 2 minutes to mask a wheel this way.
Pretty much done -- except for the handle; which was shot in gold as well
OK!! Here's the finished product!!!
BEFORE!!!
AFTER!!!
Believe me guys -- this will be no "shop queen" -- it'll get used "like I stole it". So take a good look. In three months it'll be somewhat scratched up and quite dirty
like most of my tools  :toothy9:
I'm beat -- these two day resto marathons are gettin' a little tiring :toothy9:  Time for an adult beverage! :headbang:
