The Craftsman Intermediate Chest =
Started by goodfellow, Jan 19, 2025, 11:15 AM
This is very much in keeping with the old style chests. Thick steel, sturdy drawers on ball bearing slides, and a really good finish. Nothing "homeowner quality" about this one. Just proves that Sears still has a few outstanding products. The manufacturer code is 706, and it doesn't show up on the old lists that are posted on line. Anyone know which company is associated with the 706 code?
This is a pretty nice toolbox stack. It may be a bit high for me, but it rolls and swings easily; so we'll see if I can work with this thing over the long term.
I'm pretty impressed for the price ---
I have been using a simple step to access my 1/2" stuff in both my SAE & metric boxes for a few years now due to adding mid boxes, but I needed the extra room the mid boxes offered.
Using the step is a minor, but necessary inconvenience for me.
Adding the mirror in the lid of the metric box helped measurably. Now I just need to find the time to do the same thing on the SAE box.
Quote from: Uncle Buck on May 05, 2025, 10:33 PMI have been using a simple step to access my 1/2" stuff in both my SAE & metric boxes for a few years now due to adding mid boxes, but I needed the extra room the mid boxes offered.
I like the mirror idea -- I'm a short guy these days, and shrinking more rapidly as old age sets in. I started out at 5'-9" back in my late teens and am now 5'-7" -- quite a drop, and a step stool and mirror is the right solution
i have heard of mirrors on the ceiling to  keep an eye on your tool but never on the toolbox lid......... 8)
Quote from: skfarmer on May 06, 2025, 08:28 PMi have heard of mirrors on the ceiling to  keep an eye on your tool but never on the toolbox lid......... 8)
I use plate mirror i buy cheap at the restore. I remove the mirror from the frame, then cut to size on the glass machine at my local hdw.
Next step is epoxy a piano hinge along the bottom edge of the mirror. Drill holes on the side of the hinge where it meets the underside of the lid and through the lid itself, then pop rivet in place. If you don't want to drill holes apply a generous length of velcro to the back of the hinge and bottom of the lid.
At the top corners of the mirror epoxy very small chain. A small hook and eye type setup or similar can be secured on the underside of the lid to match the mirror corners.
This setup will allow the mirror to tilt down/away from the underside of the lid and reflect the contents. A good light above doesn't hurt either!
Getting the hang of picking tools by guiding your hand using the mirror was a bit of a learning curve for me.
I have the same problem - too short to see the top of the top chest. My solution is a single step stool. I used to have a Kik-Step but it got appropriated to the pantry by the management.
I recently watched a YouTube video where a guy wanted one of these mid boxes , but they're apparently desirable and command a premium on eBay so he took another craftsman box and cut the top off to make this mid box.
the prices he showed on eBay for these mid boxes was kinda crazy.
I watched that same video and the guy did a great job too. Inexplicably to me, mid boxes have always commanded prices beyond what I thought they were worth. Years ago Sears brought out a single drawer 40" add on box for their 40" wide boxes and I drug my heels on buying one because I didn't want to have to use a step to reach my 1/2" drive stuff in the top till.I nearly waited to long. I think I may have bought the last one remaining in Topeka in the last year Sears had a store in Topeka. The box was a black mismatch to my red set which I sprayed a matching red prior to installing it. The match was close enough to pass muster with me. I never regretted adding the wide drawer and have since filled it to capacity. I did add a 3' wide by 6" tall step that sits at the base of my box and grew accustomed to using it in time.
Quote from: j.a.f.e. on Oct 27, 2026, 11:50 AMI have the same problem - too short to see the top of the top chest. My solution is a single step stool. I used to have a Kik-Step but it got appropriated to the pantry by the management.
I luv Kik steps! I have 2 steel ones in the shop I found dirt cheap used at state surplus, and one plastic one in the kitchen. Kik steps r the bomb!
