A discussion of everything 1/4dr
Started by Hickory n Steel, Jan 22, 2025, 05:35 PM
i recently picked up the crom ratchet of that size, the t handle/extension version.
it along with the vim locking flex t handle version i also picked up live in my hf icon socket/bit set. with a shoehorning they all fit in the case.
a very comprehensive set with 3 different ratchets, 6 various extensions, a drive handl, 22 sae and metric sockets and nearly 30 assorted bit. all in case approx 6x4x2
Quote from: skfarmer on Mar 06, 2026, 09:12 AMi recently picked up the crom ratchet of that size, the t handle/extension version.
I have just never understood the T handle feature on the standard and mini length versions.
On the long version like the VIM RBF400K you have room for your hand to actually spin it, but that spinning action is the only reason I see for the T handle feature.
Using it in a fixed T grip position makes absolutely zero sense to me when you get more leverage from the center of the bit when using it normally as a bit ratchet, plus it ratchets.
i see it more as an added feature. i don't hate it and it doesnt alter the usefulnes of any other feature so why not?
i have on many occasions used the extension slid into the handle to get the ratchet closer to the work. especially as a guide to hold bits straight on initial breaking free or final tightening.
i have a tractor that has 2 transmission sensors that are notoriously hard to get at. one under each side of the cab. you can see them plain as day, but they are arm deep under there and they were a cuss fest the first time i changed one, years ago before the advent of these pass-through t handle ratchets. it made a real sob of a job easy peasy
Quote from: skfarmer on Mar 07, 2026, 07:47 AMi see it more as an added feature. i don't hate it and it doesnt alter the usefulnes of any other feature so why not?
I have done that too.
The T position is useful in some cases on some of them, just not the stubbiest version and only truly useful on the longest version unless you had 2 extensions.
