Derusting steel
Started by Uncle Buck, Nov 07, 2025, 10:33 PM
Over the last couple of years I have restored many hand tools and devices and hand tools. Most things I restore has gone through an Evaporust bath as part of this process.
Recently I took on my most challenging heavily rusted piece yet, a cast iron tea/water pot.
Due to the quantity of soaking solution needed to totally immerse the pot i chose to use household vinegar (approximately 5%) after much research i following the advice given by most relative to the topic. I used 2 gallons of 5% vinegar and diluted it with one gallon of water. (Dilution with 2 gallons of water is what is suggested by most sources i found) i used 1 gallon due to extreme internal corrosion of the pot.
After 4-5 days soaking the exterior of the pot cleaned up like new with no evidence of damage to the exterior of the pot even after it's long soak.
The inside remains heavily corroded and i am contemplating switching gears and using 30% cleaning vinegar for the inside surface of the pot.
As many of you likely know, 30% vinegar is 6 times stronger than regular 5% vinegar. 30% vinegar is much more hazardous to work with compared by some to muratic acid.
Serious precautions must be taken to use 30% vinegar such as PPE and a number of other precautions.
I have strong reservations about switching to 30% vinegar and so far have  held off doing so due to everything I have read so far.
So, for my question. Has anyone here ever used 30% vinegar to de-rust steel and would you please share your thoughts relative to this subject.
My current thoughts are I could realize better results switching to electrolysis  to clean the pot. That said I have reservations about going that route too.
Ive done 1 gal of vinegar to 1 cup of salt..
I`ve had excellent results obviously you have to degrease the part completely.
The rust just washes away under water.
I do then soak it in bi carb soda and water to neutralize and acid remaining.
Best part ingredients can be bought at the $1 store.
Quote from: jabberwoki on Nov 08, 2025, 08:10 AMIve done 1 gal of vinegar to 1 cup of salt..
I assume you did this with regular household vinegar, inexpensive 5% stuff. I didn't know anything about adding salt. Maybe that would have helped.
I am talking about using 30% vinegar,  six times as potent, aggressive and hazardous as 5% vinegar.
I stopped by a neighbor that is a retired HS chemistry teacher of 30 plus years and discussed my concerns with him about doing this safely. I now intend to use goggles and heavy rubber gloves as a precaution. I will pour about an inch of the 30% vinegar in the pot and set it outside and see how that goes. If I have good results with that, I will totally fill the pot and go after it much more aggressively. This will set outside as a safety precaution due to the gasses produced by this more aggressive vinegar.
Ok i`ll watch for an update.
Quote from: jabberwoki on Nov 09, 2025, 09:09 AMOk i`ll watch for an update.
I'll let you know ow how it worked in a few days.
I need to get back to this, weather turned and I haven't been in the shop in weeks. My current project in the house is dismantling a vintage upright piano one piece at a time to dispose of to stay busy.
