Protective Arm Sleeves
Started by Mr_Breeze, Jul 03, 2026, 12:14 PM
Mr_Breeze
I'm getting ready to do a transmission pan drop/filter change/fluid refill on my 2016 F150.  Since Ford had a better idea and eliminated the dipstick tube, I am forced to check the final fluid level from under the vehicle.
To make it more fun, the final fill level must be checked at operating temperature with the vehicle running.  So I'm going to be sticking my arm up between the transmission and a fully heated catalytic converter.
Does anyone have any recommendations for a protective sleeve I can slip on to minimize the chances of getting burned?  Been shopping the Jungle and nobody really says what kind of temperatures their product are good for.
It appears my hypocrisy knows no bounds!
Jerry
I'd try a welding jacket and gloves.
Mr_Breeze
I ordered a set from The Jungle.  They are Mechanics Wear brand.
I already have a welding jacket and gloves so I think I have the bases covered.
I will post once the sleeves arrive.  Thanks for the suggestion Muddy!
Jerry
Mr_Breeze
I finally got around to changing the fluid in my transmission.
I used a heat sleeve and a welding glove for adjusting the fluid level.
No drips and no burns so I'm declaring Mission Accomplished!
Jerry
Yeah its a bitch , ive had blisters from doing that job.
I did install an aftermarket dip stick but its bloody junk so out it came.
WOW,Ford must have had the dummy engineer that little prize eh!
Mr_Breeze
Probably a "bean counter" driven change!
Some genius in accounting found a way to save $5 per transmission so it got forced into production.  The mechanics out in the field get to deal with it now!
Jerry
I have a set of insulated sleeves that I use quite often. They have saved me from some significant exhaust burns.
https://www.amazon.com/dp/B01C5GBSDY
